configure iproute delete blackhole
configure iproute delete blackhole [ipv6Netmask] {vr vr_name}
Description
Deletes a blackhole route from the routing table.
Syntax Description
ipv6Netmask Specifies an IPv6 address/prefix length.
vr_name Specifies the VR or VRF from which the route is deleted.
Default
If you do not specify a VR or VRF, the current VR context is used.
Usage Guidelines
A blackhole entry directs packets with a specified destination address to be discarded. Blackhole entries are useful as a security measure or in special circumstances where a specific destination address must be discarded. Blackhole entries are treated like permanent entries in the event of a switch reset or power off/on cycle.
The following example deletes a blackhole route from the routing table for packets with a destination address of 2001:db8::3452, so the packets are no longer discarded:
configure iproute delete blackhole 2001:db8::3452/128
Support for IPv6 was added in ExtremeXOS 11.2.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
